  1. I finally got my DVD ready to burn after testing it on my PC. I put in the last DVD+R I have on the shelf to burn using Nero Express (which I have used with no problems 8 times before this) and after the burning starts I get the message "Power Compatibility Error...Burn Failed". What the...?
    "Can You Dig It!"
  2. your burner don't like this kind of DVD+R... go buy a better quality
    btw what is your dvd drive ?
    IF your profile is ok, then Pentium 300Mhz is under the minimum requiment for a DVD burner.. you better need to look for an upgrade (P3 500Mhz and higher is the minimum with 64mb of memory and win98SE)
  3. Originally Posted by vric
    I have a TDK indiDVD 4X burner and use TDK media. Like I said I have burned 8 successful DVDs with the same media with no poroblem, so I think your right in that I need to upgrade my processor. Quess I'll have to save up for that P4
    "Can You Dig It!"
