Hello I finally got everything to work.
Now i'm trying to capture the dv video from my JVC DV Cam with premiere. It captures fine with 0 dropped frames but i think the video is interlaced because i see those faint lines when somebody moves. I've checked in premiere but i don't Premiere has a capture setting to deinterlace or do something like that.
What i want to do with the movies is edit them and put them on DVD Video so i can watch them on a stand alone dvd player, but i'd also like to watch them on the computer someday.
The question is:.
Is the lines in the captured movie normal ? Do i have to deinterlace it later ?
I'm very new in this interlacing things although i have read how it works.
Could somebody please give me an advice ?
"Against All Odds"
DV is interlaced. Remember that you don't really 'capture' DV, more do a direct digital copy of the data from the tape to the HD. It is normally stored in an avi wrapper to allow the PC to use it. If your target playback device is a TV, keep the material interlaced (unless you are going to VCD which is mpeg-1 and does not support interlacing). As for PC playback, PowerDVD has a built-in on-the-fly de-interlacer, so try that.
Thanx bugster.
That's a good explanation. Really helped me a lot."Against All Odds"
Problems Capturing/Importing Video into Adobe Premiere Pro
By Texas in forum EditingReplies: 3Last Post: 15th Apr 2010, 02:56 -
Convert Video using Adobe Premiere Po CS3
By SB4 in forum Newbie / General discussionsReplies: 11Last Post: 5th Feb 2010, 01:43 -
Adobe Premiere 2.0 Video Lagging! But Why?
By daiweb in forum Video Streaming DownloadingReplies: 2Last Post: 19th May 2009, 10:13 -
Video problem in adobe premiere pro 1.5
By saifshuvo in forum EditingReplies: 1Last Post: 5th Apr 2009, 15:16 -
Capturing Video to Adobe Premiere CS3 (USB)
By Haz567_a in forum Capturing and VCRReplies: 4Last Post: 27th Jul 2008, 03:31
