Guys (and Gals) needing some help here,
I have a split avi that I have joined together, then converted to DVD, this is aprox 6Gb.
I have tried several softwares, read loads of conversion guides, but cant seem to find the solution to my problem, does anyone know how i can shrink it down further i.e. to fit on a dvdr
the avis were joined and exported to dvd with Ulead movie factory, dvd shrink (2.3) wont shrink it, TMPGnc wouldnt encode the avis to mpegs without loosing sound, and im at my wits end.
any ideas?
Results 1 to 9 of 9
Noob alert!
What do you mean tmpgenc would not do it without losing sound. Do you mean sync problems ?.
My answer would be to convert in tmpgenc using a lower bitrate but before you can do that we need to work out what you mean by losing sound.
Post back
Russell -
cheers ladydaddy,
file=" File : 693 MB (693 MB), duration: 1:17:21, type: AVI, 1 audio stream(s), quality: 63 %"
video= "Video : 610 MB, 1103 Kbps, 25.0 fps, 640*272 (2.21:1), DIV3 = DivX v3
MPEG-4 (Low-Motion), Supported"
Audio= "82Mb, 149 kbps, 48000 Hz, 2 Channels, 0x55 =MPEG Layer-3, Supported"Noob alert! -
I left it at default (both video and audio), ive alos checked, their is only one file
Noob alert! -
I'm not sure why TMPG has a problem with the audio but try saving the audio as a wav file and using that for the audio in TMPG. You can do this with Virtual Dub. There is a guide in this web site for saving an avi audio to wav.
I dont know why it wouldnt convert the audio, However I have now "fixed" it, but using VirtualDub to split out the uncompressed auido into a wav, then combine the audio and avi video using TMPGEnc into a MPEG, then using DVD workshop to create a DVD,
thank you all for your responses!Noob alert!
1GB AVI to DVD doesn't fit on DVDR?
By juggaloninjachoo in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2012, 14:32 -
Got two .avi files and need to pare them doen to fit on one dvd, help!
By BroCraig in forum ffmpegX general discussionReplies: 8Last Post: 25th Aug 2009, 13:35 -
AVI to DVD - Movie doesn't fit on screen
By tmac2085 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 11:18 -
why won't my avi fit on a dvd-r
By bigwheels103 in forum Newbie / General discussionsReplies: 3Last Post: 24th Oct 2007, 22:08 -
How to get large avi to fit on dvd while keeping quality
By BrettO in forum Newbie / General discussionsReplies: 6Last Post: 3rd Oct 2007, 09:54
