NEVER HAD PROBLEM WITH CLONEDVD. BUT LAST NIGHT USING A PRINCO FOR THE FIRST TIME HAD AN ERROR BURNING. ALTHOUGH THE WHOLE FILM IS BURNED AND ALSO CAN SEE ON TV PLAYER
Please don't yell.
I've used Princos once before with CloneDVD and I didn't get any error messages at all. Of course, I would never use them again because the disc didn't burn at the rated speed (1x instead of 4x).
What did the error message say? The fact that you were able to view the movie was rather strange though. -
THE ERROR MESSAGE IS "UDF 5 65536"
ITS VERY STRANGE. IF YOU TAKE A LOOK AT THE DISC YOU CAN SEE THAT THERE IS STILL A LITTLE BIT BLANK AT THE END OF IT. MAY BE SOME KIND OF FILE IS MISSING. ??? -
Only reply if you have something worthwile to say you ain't a policeman.Originally Posted by Kernal
Chano8 so wheh you burn it gives you an error but everything is fine on the disc ?, strange. What speed are you buring at ?, have you tried a reinstall of the software ?, have you tried different media ? -
MPEGit has some tests for various media brands (blank discs) on various drives http://www.mpegit.net/dvdr_quality.php. Check to see if your drive and media have been tested.
Incidentally, no one has explained but typing in all in capitals on the net is considered shouting.
free software for burning data dvd in ISO (not UDF) file format
By Toastie in forum MediaReplies: 3Last Post: 29th Oct 2010, 18:18 -
Burning with UDF
By gooberguy in forum Authoring (Blu-ray)Replies: 9Last Post: 18th Jul 2009, 18:01 -
Clonedvd error"Media Write Error"
By demonwarrior in forum Newbie / General discussionsReplies: 1Last Post: 4th Sep 2007, 03:49 -
Clonedvd error"invalid block start code"
By demonwarrior in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 06:01 -
UDF or ISO when burning a multi DivX DVD-R
By perceptionist in forum DVD RippingReplies: 3Last Post: 4th Jun 2007, 14:10
