Hey guys,
i bought a dvdwriter yesterday, and i haven't created anything yet so i'm still a complete noob. I have some svcd lying around and i would like to put them on a dvd but i was wondering how to do it. I already found out about the dvd lab method and was planning on trying that, but what happens with the switchable subs i have on my svcd, will they stay and will i be able to see them on my dvdplayer?
Thanks!
I would guess: No.
What I think I know:
- SVCDs support 2 different sub standards
- SVCD subs are a private stream muxed in the mpg
- DVD subs are a stream muxed in the VOB
- Oscars method has you demux the m2v, fix the mpa
- DVD-Lab does not support subs (unless the streams are already muxed)
However, There are about 10 guides on how to put svcds on a DVD:
https://www.videohelp.com/guides?tools=&madeby=&formatconversionselect=SVCD+to+DVD&ossel...or+List+Guides
Maybe one can give you a clue. Also, there is a svcd2dvdmpg forum on the site. This may have some ideas.
My guess would be you have to demux the subs (don't recall how for svcd), and re-author with something like ifoedit. You could then used dvd-lab to create the menus (or even to fix the sound).
Hope this helps !
DVD to h.264 -- with multiple audio and subtitle tracks
By Ozo in forum DVD RippingReplies: 12Last Post: 16th Nov 2012, 07:34 -
dvd to mkv but allow multiple sound/subtitle tracks
By chris789 in forum DVD RippingReplies: 6Last Post: 7th Feb 2012, 12:03 -
How do I burn multiple subtitle tracks to a DVD with ffmpegx
By wildgeese in forum ffmpegX general discussionReplies: 6Last Post: 26th Feb 2009, 12:54 -
One .PHP Subtitle File, multiple films to subtitle!
By ulrichburke in forum SubtitleReplies: 0Last Post: 20th Mar 2008, 17:32
