If some of my created dvds wont play on standalone players , if i apply 'force DVD complient for xbox, is their a possibility this will help to make them playable, ive tried the utf 1.02 but still some wont work and it is able to play vcds.dvdrs , the lot
Ive made the dvds as dvd utf and also dvd video before and found that the dvd video copy made wouldnt work on my standalone for some reason. Any reasons why?
Standalones are a lot more picky than computer-based DVD players. You have to adhere more strictly to the plain-vanilla DVD standard to get your DVDs to play in most standalones. (Though your DVDs will rpobably never plays in ALL standalones of all makes & maodels.)
Rules of thumb:
[1] LImit your DVD length to 1 hour max. (Yeah, I know. But what can you do? Pro DVD authoring programs like DVD Maestro won't even allow you to create single-layer DVDs as long as 90 or 120 minutes. They'll give you an error mssg and refuse to author 'em.)
[2] Use UDF 1.02 instead of 1.05 if you're burning from an ISO image using the DVD ROM setting. (If you burn from Spruce or Prassi, those programs take care of this uatomatically for you.)
[3] Make sure your DVD encoding settings are within the official DVD spec. That means 720 x 480 max bitrate 8000 min bitrate 2000 with the box checked to force a minimum date rate of 2000. Some standalone DVD players won't play a DVD if the bitrate drops below the official minimum of 2000.
[4] Make sure you use one of the following combos for audio: [1] AC-3 only; [2] WAV only; [3] AC-3 plus WAV audio; [4] AC-3 plus MP2; [5] WAV audio plus MP2. Any other combination is not strictly within the official guidelines for DVDs and may cause problems in standalone DVD players.
Following these guidelines, I've have excellent luck getting my DVD-Rs to play on most other folks' DVD players.
How to force a smaller image to use both layers on DVD?
By Billkwando in forum Authoring (DVD)Replies: 42Last Post: 14th Mar 2011, 05:55 -
Visual Hub / DVD / Where is "force anamorphic" ?
By webstar in forum MacReplies: 2Last Post: 30th Jun 2010, 04:13 -
Creating "force-play" DVD chapters using a Mac?
By Cyrax9 in forum MacReplies: 10Last Post: 19th Jan 2010, 06:45 -
Is there any way to force rip a scratch dvd?
By tendra in forum Authoring (DVD)Replies: 13Last Post: 26th Jul 2009, 19:46 -
How to force subtitles to be shown in certain parts of the DVD?
By dexter30 in forum SubtitleReplies: 1Last Post: 24th Jul 2009, 19:58
