hey guys i just got a dvd burner and i used dvd shrink to shrink equlibrium. i made its own folder and sent the files in there. i got alot of files (.bup .ifo etc) so i tried to burn it with nero express. i clicked on dvd0video button and added all the files to the dvd. i clicked on burn and it started and it said burn process failed in the first ten seconds. so nothing was written to the dvd-r. i tried several times and the same thing happened. what am i doing wrong or what can i do thanx alot.![]()
What disks are you using? I remember my first DVD burner. I tried to burn a DVD to the disk that came with it. I had the same fail you did changed to a DVD-R disk I had bought. It worked. It turned out the disk that came with the burner was a DVD-ROM disk.
Hello. -
I use Nero Express exclusively to burn all my DVDShrink files, and have never had a problem. You did not mention what type/brand of DVD burner you are using or what brand media it was that came with your drive.
There may be a firmware update for the burner. Or, you may have have the burner set to slave, when it should be a master. Or, the transfer mode in your PC may be set to PIO instead of DMA.
More info is needed to help you out.Burn Baby Burn
It's a Disk-o Inferno -
i was using the one it came with. lol. what burner did u get when this happened. i have a pine dvd -/+ rw. so it should work if i buy some new ones. and everything i did was correct?
You might want to try some +/- RW media. That way if you get a bad burn, you can erase the media and start again. Nero express gives you a quick erase option with RW media.
Burn Baby Burn
My friend also had this problem with Nero Express. Try using the regular Nero (instead of the Express). It worked for her. Good luck.Originally Posted by diranged
Cendyne.what burner did u get when this happened.Hello.
thanx alot Tommyknocker after i baught some new dvd-r's it worked. thanx for the help guys
Trying to burn a dvd using dvd shrink and Nero 10, please help a newbie?
By KtuluAlly in forum DVD RippingReplies: 6Last Post: 30th Dec 2010, 14:33 -
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
DVD Shrink and Nero together
By moe_b_disc in forum Newbie / General discussionsReplies: 11Last Post: 1st Mar 2008, 15:23 -
Nero Recode vs DVD Shrink
By PhoneMatt in forum DVD RippingReplies: 2Last Post: 8th Feb 2008, 14:04 -
nero 8 & dvd shrink
By jerbevpicasso in forum Newbie / General discussionsReplies: 17Last Post: 24th Oct 2007, 22:36
