Results 1 to 10 of 10
  1. Hi
    I was following the new guide for the motion menus, but when I click on the wizard tab there is no option for the Render Motion Tool. Everything else is there but not that??
    Anyone know why?
  2. Open the menu tab, it's the last thing listed.
  3. the last thing listed on the Menu Tab is - Transitions
    I have the trial version btw, does it not appear on this?
  4. Your menu tab does not look like this?
    It might be grayed out until you load a menu background.
  5. no, it doesnt have the last bit, but i think i have just figured it out, what version do you have?
    mine is 1.1 and apparently there is a 1.3 version out?
    even though i downloaded it from the company web page...
    could you confirm the version you have if possible?
    cheers
  6. 1.3 beta2
    It must be missing in the trial version.
    This program is too good not to buy.
    Trial over.
    Oct 2000
    You have to hunt for the beta. I don't believe it's located on the main download page.
    I don't have a bad attitude...
    Life has a bad attitude!
    May 2003
    Pal Realm
    All of the updates are always available through the forum. Oscar posts update details and download links there. Go to mediachance.com, then forums (called Web Boards on his site), then DVDLab.
  9. The "trial" versions are fully functional. If you don't have the option, then you might not have the newest version.
