I have converted some home video to a DVD format using various tools. I now have a valid AUDIO_TS and VIDEO_TS folder on my hard drive. How do I now burn these to a DVD? Can I just copy those folders on to the DVD using Roxio Classic Creator, or is some other tool I need to create a DVD.
Thanks!
When you say valid, you mean you can play the individual files on your computer correct? All play with vid/audio, correct? NO- EZ CD creator is not going to do a good job for you. Do you have NERO or Record Now Max? Please post back as to what other burning program you have besides the one mentioned.
Use nero and select dvd video drag your video ts file onto the one on the disc and audio ts also if you have anything in it (doubtful).
Post back if you have any problems.
Newbie Question on Burning Bluray
By discover in forum Newbie / General discussionsReplies: 5Last Post: 23rd Feb 2012, 15:35 -
Newbie question RE: burning DVDs from HD camcorder
By lcinva in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 12th Sep 2011, 09:53 -
Newbie: Need help burning movies into DVD
By silveraden in forum Newbie / General discussionsReplies: 3Last Post: 29th Nov 2010, 12:36 -
total newbie dvd converting burning
By mujin in forum Newbie / General discussionsReplies: 6Last Post: 29th Jan 2009, 12:28 -
Newbie Roxio easy cd and dvd burning question.
By mmmipa in forum Newbie / General discussionsReplies: 8Last Post: 24th Nov 2007, 22:31
