I'm wondering if the default settings of the included templetes in tmpegenc are sufficiant for a good quality final mpeg? I've been using the TIbrO VideoCD templete in the tools section? Is this a good one? What others should I try? I'm looking to make a crisp quality DVD rip. Any suggestions or directions would be greatly appreciated....
MJ USA
I've had quite good quality with the standard templates, but different problems call for different solutions so sometimes a little tweak here and there can help.
After you get used to TMPGEnc your own custom templates will be best. By that I mean if your making rips for yourself and not worrying about being VCD compliant.
I use a custom xSVCD template for all my stuff now ... but my template my be no good to you (depending on your DVD player)
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 19:14 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 10:13 -
Error with Nero AAC encoder in XVID4PSP - "Could not open AAC encoder&
By TheViking in forum Video ConversionReplies: 2Last Post: 5th Nov 2009, 02:41 -
Something better Tmpeg Enc
By 02fx4dude in forum Video ConversionReplies: 4Last Post: 15th Aug 2007, 07:23 -
Tmpeg 2.5 will not encode .avi
By WuTangDvD in forum Newbie / General discussionsReplies: 9Last Post: 20th Jul 2007, 14:01
