I have been trying do author a 5hr half d1 video with dvd-lab, moviemaker se, and moviemaker 2.
Everything seems to work fine untill i try to add a selection menu at 4hr's. Actualy, the program seems to stop updating the preview screen at just under 3hr20min.
I was able to get the menu in dvd-lab but when i burnt to disk, the selection was highlighting spots not on the icons. Also, the audio was way!!! out of synch.
Any ideas?
Rod
Results 1 to 1 of 1
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 14:16 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 09:35 -
Half the disk is formatted PAL, the other half NTSC...Doable or not???
By AlecWest in forum Authoring (DVD)Replies: 15Last Post: 16th Oct 2007, 09:31 -
Uploaded video cut in half only top half shows
By MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 11:55
