i got a problem when encoding to svcd.when i try to encode to svcd on my other computer a shade of purple or pink usually appears every 20 or 30 seconds. its weird cause i dont get the same problem when i encode on my other computer with the same avi. what can i do to fix this?
Having the same problem here. The video image seems to cycle efery 20-30 seconds to a more pink/purple tone, only to reset itself to the proper color and start again. It is inconsistant, as it won't do it for all of the divx files I convert. I believe it could be tied to frame rate differences simply because it seems to be happening for me only on divx files with non-standard frame rates (ie 14fps and others).
I read something about the possibility of it being related to the presence of the "Angel Potion" codec on my system, but I don't know much about it. Searched my hard drive for "angel" but found nothing.
Any help would be GREATLY appreciated!
Thanks in advance!
Encoding .Avi to Svcd?
By mrjust in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2011, 14:40 -
Encoding VIDEO_TS to mpeg-2 SVCD
By phamtom in forum ffmpegX general discussionReplies: 6Last Post: 27th Apr 2008, 16:05 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 12:41 -
Different dye coloration after burn (TDK DVD)
By xSimonx in forum MediaReplies: 2Last Post: 24th Sep 2007, 21:29 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56
