Results 1 to 9 of 9
  1. Hi folks, I have a question I'm hoping someone can help me with. I am scoring rather low (IMHO) with Mad Onion's 3d Mark Bench test. I score at 2748 3d Mark Points. However I thought I would score in or around mid 4000's to low 5000's. My system specs are to follow
    CPU: Intel P4 Intel 3.0Ghz (800Mhz FSB w/ HT)
    Mobo: Intel D865PERL
    RAM: Kingston PC3200 512MB x2 @ 800Mhz
    Video: ATI Radeon 9800 Pro AIW (128MB)
    Operating System: Windows 2000 SP4
    What do you guys think? Any suggestions to raise the scores!?
  2. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    Gee... wish I had your machine. Is you DX up to date? Anything else running while you do this test? Try another test from someone else? Where is a link to get to this test, maybe I'll test my sad little machine.
    By your system specs, that machine should really crank! Maybe another Gig of memory wouldn't hurt, but that is getting picky. Maybe you need updated drivers for the video card? Maybe a bios update? You've probably already done all that, but there isn't much else to check. Could your hard drive be slowing things down? Is DMA enabled?
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
  3. Member The village idiot's Avatar
    Apr 2002
  4. Member The village idiot's Avatar
    Apr 2002
    OK, wrong test. But this is what one machine scored off of the free test from above.
    Operating System Microsoft Windows 2000
    DirectX Version 8.1
    Mobo Manufacturer
    Mobo Model EPIA-M
    AGP Rates (Current/Available) 4x / 1x 2x 4x
    CPU Unknown 932 MHz
    FSB 133 MHz
    Memory 112 MB
    Graphics Chipset VIA ProSavage Series
    Driver Name VIA/S3G CLE266 Graphics Driver 5.13.01.0012-01.10.01
    Driver Version 5.13.01.0012-01.10.01
    Video Memory 16 MB
    Detailed Test Results
    CPU Score 858
    Memory Score 739
    HDD Score 566
    CPU Tests
    Jpeg Decoding 2.9 MPixels/s
    Zlib Compression 1.4 MB/s
    Zlib Decompression 16.4 MB/s
    Text Search 28.3 KRounds/s
    Audio Conversion 13.5 KB/s
    3D Vector Calculation 11.0 FPS
    Memory Tests
    Raw Block Read - 3072KB 194.4 MB/s
    Raw Block Read - 536KB 194.8 MB/s
    Raw Block Read - 384KB 195.7 MB/s
    Raw Block Read - 48KB 3755.3 MB/s
    Raw Block Read - 6KB 3716.8 MB/s
    Raw Block Write - 3072KB 185.0 MB/s
    Raw Block Write - 1536KB 175.0 MB/s
    Raw Block Write - 384KB 193.5 MB/s
    Raw Block Write - 48KB 2337.8 MB/s
    Raw Block Write - 6KB 2324.3 MB/s
    Raw Block Modify - 3072KB 143.6 MB/s
    Raw Block Modify - 536KB 140.6 MB/s
    Raw Block Modify - 384KB 146.2 MB/s
    Raw Block Modify - 48KB 2077.3 MB/s
    Raw Block Modify - 6KB 2056.2 MB/s
    Random Access - 24576 (1536KB) items 182.4 MB/s
    Random Access - 12288 (768KB) items 182.3 MB/s
    Random Access - 6144 (384KB) items 183.0 MB/s
    Random Access - 1536 (96KB) items 396.5 MB/s
    Random Access - 768 (48KB) items 1235.5 MB/s
    Random Access - 96 (6KB) items 1243.7 MB/s
    Video - 1 line 335.8 FPS
    Video - 4 lines 316.9 FPS
    Video - 16 lines 253.9 FPS
    Video - 32 lines 202.6 FPS
    Hard Disk Tests
    Cached File Write 18.4 MB/s
    Uncached File Write 27.2 MB/s
    Cached File Read 9.5 MB/s
    Uncached File Read 26.9 MB/s
    File Copy 7.9 MB/s
    Crunch Tests
    Jpeg Decoding 2.1 MPixels/s
    Raw Block Modify - 3072KB 62.5 MB/s
    Blit Test 66.4 FPS
    Pro Version - Windows XP 2D Tests
    Lines N/A
    Ellipses N/A
    Arcs N/A
    Beziers N/A
    Curves N/A
    Filled Ellipses N/A
    Gradient Boxes N/A
    Gradient Polygons N/A
    Filled Pies N/A
    Images N/A
    Cached Bitmaps N/A
    Strings N/A
    Pro Version - Video Performance Tests
    ASF Compression - Low N/A
    ASF Compression - High N/A
    ASF Playback - Low N/A
    ASF Playback - High N/A
    DVD Playback - Low Quality N/A
    DVD Playback - High Quality N/A
    Pro Version - Video Quality Tests
    Line Flicker N/A
    Feathering N/A
    Double Images N/A
    Jaggies N/A
    Tearing N/A
    Note: no 3D testing.
    This is an Epia M-9000 itx board, with a lowly ata33 hard drive, and shared memory. I'll see if I can find a free 3D reference.
  5. Member The village idiot's Avatar
    Apr 2002
  6. Member The village idiot's Avatar
    Apr 2002
    Same machine with DX9.0b
    DirectX Version 9.0
    Mobo Manufacturer
    Mobo Model EPIA-M
    CPU Unknown 932 MHz
    FSB 133 MHz
    Memory 112 MB
    Video Memory 16 MB
    Program Version 3DMark2001 SE
    Resolution 800x600 16bit
    Texture Format 32bit
    FSAA Disabled
    Z-Buffer Depth 32bit
    Frame Buffer Double
    Rendering Pipeline D3D Software T&L
    3DMark Score 440 3D marks
    Game 1 Car Chase - Low Detail 4.7 FPS
    Game 1 Car Chase - High Detail 1.3 FPS
    Game 2 Dragothic - Low Detail 4.4 FPS
    Game 2 Dragothic - High Detail 1.4 FPS
    Game 3 Lobby - Low Detail 15.6 FPS
    Game 3 Lobby - High Detail 7.0 FPS
    Game 4 Nature No hardware support
    Fill Rate (Single-Texturing) 96.5 MTexels/s
    Fill Rate (Multi-Texturing) 123.0 MTexels/s
    High Polygon Count (1 light) 0.6 MTriangels/s
    High Polygon Count (8 lights) N/A
    Environment Bump Mapping No hardware support
    DOT3 Bump Mapping 20.1 FPS
    Vertex Shader 2.1 FPS
    Pixel Shader No hardware support
    Advanced Pixel Shader No hardware support
    Point Sprite 0.2 MSprites/s
    I had to use the 3D2001 bench mark. The newer 3D2003 would not run!
  7. Mine:
    CPU 4450
    Mem: 3100
    hdd score: n/a
    I'm proud considering I got more than a 3.0 Ghz P4 on a 2Ghz celeron!
  8. Member The village idiot's Avatar
    Apr 2002
    Contrast, again the 3D2001 tests. The machine in my profile only gave a 3D score of 850.
  9. Yeah thanks for your responses, I have DX9 as the test requires it and it comes with the ATI Drivers. Since all my hardware is so new I figured my drivers don't need updating. I will check into the ATI Drivers, but I don't want to do a BIOS flash since everything is working properly on that end of the stick.
    HOWEVER I determined today that I am going to get another Hard Drive and run it in RAID Mode 0 since I hear that really helps with Hard Disk speed. I have a Western Digital 7,200 RPM UDMA 100 100GB Drive now, so I really don't think the Hard Drive is the problem. I know I can get faster ones but that should suffice, and since I'm going RAID I will get double the throughput. Any other suggestions folks?
