hi,
I just got a new video capture card (pinncle PCTV Pro) and its great to watch TV on but when i go to capute using the included software it freezes when i try to do anything at all, and when i try to capture in vdub it is stuck on a certain channel, is there neway to change this cause the channel its stuck on has nothing on it i want to record. btw, i'm the video is coming from the cards tuner, should i try the compostie in or the s-video instead? thanx for your help.
System specs:
1ghz amd tbird
2 30 gig ata100 7200rpm hdd
pinnicle pctv pro
384mb pc-133 ram
geforce2 ultra w/ 64mb DDR
16x DVD
8x4x40 CD-RW
Results 1 to 1 of 1
-acodec copy to 6 channel audio results in 2 channel?
By ninethirty in forum Video ConversionReplies: 1Last Post: 11th Feb 2011, 12:54 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 22:46 -
Multi-Channel sound on 4350 not working 100%, (ONLY 2-channel)
By THX-UltraII in forum AudioReplies: 1Last Post: 20th Feb 2009, 05:35 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 17:47 -
stuck with only one HD channel
By rallynavvie in forum Media Center PC / MediaCentersReplies: 4Last Post: 1st Aug 2007, 14:32
