I am very new to my dvd-rw drive and the software that I got but I am looking for a little help. I am currently running an external Pioneer 106 on firewire, this works absolutley fine when backing up backups etc
I want to backup an original, so i uses dvddecrypter to rip the original to a file and then "Intervideo" to burn to a disc, this works fine and I have had no problems.
I know you cannot fit a whole dvd onto a disc due to that most dvd's are dual layer nowadays, Is there anyway of keeping the main menu from the original and adding that to the backup ? I know the extra's will not work, but would like the menu.
Apologies if there is a guide for this that I have missed but I gotta start somewhere.
Thanks In Advance
AJ
Try this:
https://www.videohelp.com/forum/userguides/175347.php
And there is a tool caled menuedit that will allow you to take out items from the menu that are no longer active.
Can you rip a dvd without the menu requirement...plz read for nfo.
By darkcyber in forum DVD RippingReplies: 5Last Post: 11th Jul 2011, 23:45 -
How to rip BD with top menu + hd audio?
By dougw03 in forum Blu-ray RippingReplies: 6Last Post: 10th Jun 2011, 14:55 -
How to rip (DVD,HD DVD, Blu Ray) with chapter and menu in 7WMC?
By timf79 in forum Blu-ray RippingReplies: 1Last Post: 19th May 2011, 23:34 -
Rip DVD menu audio
By Silver_Ice in forum AudioReplies: 7Last Post: 28th Mar 2008, 00:33 -
After rip DVD menu not working, any suggestion?
By taylor6698 in forum DVD RippingReplies: 1Last Post: 3rd Oct 2007, 16:10
