Hey so I bought a new toshiba satellite which supports usb 2.0 and then I got the Sony DU500 external dvd+/- burner which is also USB 2.0. I used dvdDyctpter to rip the dvd to my HD and then when I use it again to write the dvd I get an I/O error. The dvd isn't not encypted at all
Does anyone know what I should do? If you need any more info please let me know. Thanks
Did you defrag the hard drive before trying to burn the DVD? Usually after ripping a DVD, I defrag the hard drive I ripped to, then reboot the computer, then burn the DVD. I use RecordNow Max, and if I fail to do any other those things before burning a copy, I get error messages.
Errors burning movie to BD-R using HP bd340i burner & PowerProducer softwar
By BDNov in forum Authoring (Blu-ray)Replies: 1Last Post: 15th Feb 2011, 09:34 -
Explanation for Samsung Burner Errors
By Seeker47 in forum DVD & Blu-ray WritersReplies: 3Last Post: 14th Jul 2009, 12:16 -
Errors playing Blu-Ray films on LG Burner,
By havash in forum Software PlayingReplies: 7Last Post: 21st May 2009, 00:00 -
I/O errors with my new Pioneer DVR-115D burner
By gshelley61 in forum ComputerReplies: 4Last Post: 12th Jul 2008, 15:25 -
ImageSource giving errors when reading Photoshop .bmp files
By DVD_JS in forum EditingReplies: 0Last Post: 20th May 2008, 19:21
