what is the recomanded VBR pass for CCE?
I know that higher is better but is there a difrent between 3pass and 7pass?
5pass and 10pass?
Results 1 to 10 of 10
I only use 2 pass unless I'm shrinking a movie longer then 2 and half hours in CCE. If its longer then that I use 3 pass. Remember each pass add ALOT more encode time.
I wanna backup LOTR TT that is more than 2hr...do you think 3 pass will be enough? how about 5?
3 should be ok, 5 should be more then enough. If you just want to ensure its as good as possible set it at 5 and just let it run, just remember its gonna take a while.
great, so there is some difrents between 3 and 5 ? so if it is why not puting 7pass?
time?
if it is just time so its ok for me....
I have a dual CPU AMD MP2000+ with 2GB DDRam...
it will be faster...
Ive always used 4 or 5 pass' when i used CCE for Svcds, but i aways use 5 pass' for dvds.Some people will say 5 + pass' is just overkill.But ive always had really good picture reasults with 5 pass' so i stick to that.
Big 3 User.....
PAL User....... -
Has there been any comparision between cce and dvd2one or dvdshrink. How do these programs re-encode? and how many passes do i need to run to get better quality than one of the allinone sollutions. Because lets face it, if you back up a movie and keeping menues and some audio-track some subtitles. and then encode with cce, it takes a while and you need to get it back in "one piece".
According to the CCE 2.5 manual.
3~4 passes is max. Anything beyond this will yield very minor improvments. I use 3 myself.Don't give in to DVD2ONE, that leads to the dark side.
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 22:11 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 07:59 -
1 pass and 2 pass bit rate query
By socrates in forum Blu-ray RippingReplies: 1Last Post: 26th Nov 2010, 16:18 -
AVIDemux 1-pass vs. 2-pass Configuration Question
By robindean in forum Video ConversionReplies: 2Last Post: 12th Mar 2010, 20:32 -
Retrospectively check if One Pass or Two Pass Encoding was used?
By BenjaminBS in forum Video ConversionReplies: 4Last Post: 26th Nov 2009, 06:46
