Guys,
I've been using TMPGEnc to encode my anime to MPG2, but lots of times you'll get a bit of the screen cut off...enough sometimes to slice into the subtitles. Is there a setting in TMPGEnc where I can adjust this?
Thanks a million...
Do a forum search for "overscan", you'll find a lot of information about your problem.
A man without a woman is like a statue without pigeons. -
If you are using the Wizard, on the Filter Setting page click on Other Settings, then on the Advanced tab. Where it says Video Arrange Method, select Full screen (keep aspect ratio) from the drop-down list. Do a short encode as a test. If you're not happy with the results, you could also try using the Center (keep aspect ratio) setting.
Hope this helps!
Movie to big for screen??
By bunkerhill in forum Newbie / General discussionsReplies: 6Last Post: 4th Jan 2010, 06:09 -
streaming anime no subtitles showing half the time/off screen
By thewhiteboy23 in forum Newbie / General discussionsReplies: 17Last Post: 18th Oct 2009, 13:46 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36 -
Anime DVD to X264 with Staxrip - is it worth using the 'anime' setting?
By Emanef in forum DVD RippingReplies: 2Last Post: 8th Nov 2008, 16:31 -
Using My Big Screen For Pc Monitor
By Robspace1 in forum DVB / IPTVReplies: 11Last Post: 13th Jun 2007, 13:55
