Hi,
using Sefy's method to rip my first DVD. So far so good, but there are SO MANY templates available for the final mpeg encoding stage. I'd appreciate a quick pointer as to which one I should use for VCD to play on an APEX DVD player.
Also, step one of the process (the smartripper step) went as expected and took ~8 minutes on a PIII 1gig, but step 2 (dvd2avi)took 1hr 20min instead of the ~15 minutes shown in Sefy's example!! Any ideas if there's something wrong or is this kind of variation normal? (BTW I was reipping a 1Hr 20 min standard format cartoon DVD).
Thanks for the help
I haven't ever had DvdToAvi last longer than 30 minutes. I have an AMD 900 with 512 Ram. I like the standard templates (NTSC). Did you follow these steps, 1. Open vob. 2. Enter Name to Save. 3. Save Project.
yes! those were the exact steps I used.
I let it finish it took the full 1:20. I stopped the process once and rebooted the PC just incase....the second attempt took just as long. On the upside, the process completed properly, but the time used was ridiculous specially sincd the PC is a new PIII 1gig 256M 133 RAM and the HD has 14gig free!
Are there other settings in DVD2AVI that might have slowed this down (resolution, etc?) I have not fooled with the default values, but not knowing what the defaults are it is hard to check.
thanks -
i done 7 samurai it only took 40 mins and it ended up using 11 gig i would try re installing a different version if i was you just incase
a different version of DVD2avi?
I have version 176 (?) loaded. Maybe I can just re-install it
comments? -
Check your audio setup....If you have the "48 -> 44.1" setting set for high, or ultra-high, it can take a long time...
cheers,
boykster
Template for effect.
By tomofthefuture in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2011, 17:04 -
AVC/H.264 Blu-Ray Template for TMPGEnc 4.0 Xpress?
By CubDukat in forum Video ConversionReplies: 8Last Post: 22nd Sep 2010, 11:52 -
Printing Template
By mleb33 in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2007, 09:09 -
Substituting Variables in a Wiki Template
By thecoalman in forum ComputerReplies: 1Last Post: 14th Jul 2007, 05:00 -
Template selection in CCE...
By hiimbored in forum DVD RippingReplies: 5Last Post: 28th May 2007, 19:54
