Hello,
I was hoping I could get some expert opinions on my video capture. This is just a little 5MB snip of an analog TV capture that I did using the MJPEG codec with a 19 setting and a 2 pass VBR SVCD encode with TMPGEnc.
http://www.pe.net/~hiflyact/test2.mpg
Thanks everyone
Well i wil agree that it is a video, but the quality isnt all that great to be made into a SVCD try a VCD and as for the video itself it isnt that great maybe try a different codec for capture or a different source (s-video maybe) cause the video itself looks like it was painted on a canvas there is like micro dots on it did you use any filters? just looks weird might be you're analog connection.
[ = Check out my band @ www.samadhirock.com = ] -
Well, the reason for making a SVCD is, because the show is 44 mins without commercials. Using the 2 pass VBR method I can get the whole show on 1 CD with pretty good quality.
If I encode it to VCD the file size ends up being about 450MB or so. I wouldn't even be able to get 2 episodes per CD unless I lowered the bitrate. VCD bitrate is low enough, I don't want it to look worse. I figure if VCD is going to be 450MB and SVCD can take up the whole disk, then why not go with SVCD, it's better quality.
I didn't use any filters. My computer is slow enough as it is for encoding, any filters I put on it slow it down even more.
Need Opinions On Video
By budwzr in forum EditingReplies: 0Last Post: 23rd Aug 2011, 13:18 -
How can I follow what title is linked to a DVD menu button?
By nzdreamer55 in forum Newbie / General discussionsReplies: 6Last Post: 11th Mar 2011, 18:46 -
Best way to capture still shots from an mpg video clip
By darkcyber in forum Newbie / General discussionsReplies: 5Last Post: 25th Nov 2010, 12:30 -
ps3 linked to home theatre
By ordinaryguyukuk in forum DVB / IPTVReplies: 2Last Post: 9th Jul 2009, 01:48 -
How to capture the audio of wmv and mpg video to MP3?
By edong in forum AudioReplies: 5Last Post: 8th Feb 2008, 00:15
