Hi board,
Hope you're all well. I have been trying to convert some of the newer files iv found online which are encoded in xvid mpeg4 to VCD complaint MPEG 1. I have tried TMPGenc which doesnt like the video stream of it, and iv also tried an application by a firm called "Zealot" which doesnt like it either.
I have searched through the forums but havn't really found a suitable solution. Can anyone help please?
Thanks,
stokefan
I said I'll be done in a minute. I meant a Microsoft minute.
Hi I adjusted the priority to +2 (all the others are 0) of the DirectShow Filter in TMPGenc, and I got a movie to encode!!
I wonder if anyone could explain to me the reason behind this please?
The reason I ask is because I tried to convert another xvid movie in the same way, but tmpgenc crashed while converting? Any thoughts? -
I went into the Environmental settings and could not find Direct show Filter to raise the settings. I have used gspot to check out the codec that was needed and it says ffdshow MPEG 4 Video Decoder. I was told to download the latest ffdshow alpha codex which I did. TMPGEnc and Divx (with the 5.0.5 codex) do not work, but ironically my Windows Media Player does work.
Please help me
When you go to the environmental section click on the vfapi plugin tab. You'll see it there.
Thanks Laddydaddy, I did what you said and it works. FINALLY!
The only bad news is that the XVID is 1 hour and 31 minutes long and to convert it to VCD would take more than 9 hours
One more thing I would like to add is that, I love this web site and without it I would be lost.
Many thanks
DVD player : Which video file is the most common, mpeg1 or xvid
By iwiiiiiiiiii in forum DVD & Blu-ray PlayersReplies: 6Last Post: 16th Mar 2011, 08:12 -
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 14:35 -
Converting Xvid to MPEG1(VCD)
By Ensign in forum Video ConversionReplies: 3Last Post: 18th Dec 2008, 16:00 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47 -
Automated XVID to MPEG1?
By SevenNine in forum Video ConversionReplies: 3Last Post: 26th May 2007, 16:52
