  1. hi all!
    First of all, let me start buy saying, english is not my native language, so donīt be surprised, whit the errors!
    Letīs get down to bussines, my problem is, my dvd player, doesnīt work whit SVCD only whit vcdīs, so i did the header trick, and it did worked, but itīs the burning part, that i dont like, why? because in all the explanations i could find in this forum, all i could find itīs: BURN WHIT NERO, and for me NERO SUCKīS for making chapterīs etc etc, and donīt even get me starded whit vcdeasy. so my question is IS IT posible to do the head trick and burn whit ulead dvd moviefactory?, i have tried but whit out sucess the program allways try to rencode video again, i ask this because for me, ulead is very, very, very simple to use, 3 cliks and your burning your (S)vcdīs. so if thereīs anyone out there who could help!!!!
    thanks in advanced!!
    I WAS YOUNG ONLY ONCE, BUT I CAN BE IMATURE FOREVER!
  2. What I did with Ulead MF2 was use DVD Patcher and choose the option to patch the entire file, Takes longer though, then author but do not burn, save to drive instead. Then Repatch the entire video files back to their original resolution and burn. In myh case since I was doing DVDs I had to run DVDPatcher against all the *.vob files that had the movie in them. On VCDs it should be the *.dat files and when that is done, Then Burn. I burn with Nero.
    Good Luck.
