I had a question i was wondering if you can help. I did a svcd file which was 3 cd's long and i managed to put it on 2 discs. now i need to put a 84 min svcd on 1 disc (which shouldn't be too hard) but i can't fit it. It reads 829 mbs on disc it shows 729 mbs. But for some i can't seem to make it fit on 1 disc. Nero is saying it's too big for my medium. My bitrate is set to 900 while the audio is 229 and i've even lowered the bitrate to 800 with the same result. Please help me
two solutions. 1 is to allow for overburning, however, there have been reports that this has ruined a burner or two. It can be done in nero in one of the options.
The other option is to set the audio much lower (96 possibly). What are you using to convert. If you are using TMPGENC, there is an option to make it fit onto one disc. -
i am using tmpgenc....and i've changed my settings accordingly the the guide. What i didn't think about was that both mpeg files are 800mbs + each. when i used dvd2avi i put both files in it and it made 1 video and sound file for both. I used that for tmpgenc. Could it be that prior to putting it through dvd2avi the files were already big and that tmpgenc squished it as much as it can?
how many MB equal GB/ how many episodes can i fit on disc?
By janeydoll in forum Video ConversionReplies: 6Last Post: 21st Oct 2010, 10:20 -
Video won't fit on dvd
By chevyfever in forum Video ConversionReplies: 5Last Post: 6th Nov 2009, 08:50 -
USB stick won't fit in printer
By csaag in forum ComputerReplies: 4Last Post: 25th Aug 2009, 21:54 -
Encoded DVD Is At 8.57gb - Won't fit on DVD9
By Brent.M in forum Newbie / General discussionsReplies: 3Last Post: 16th Jul 2009, 16:16 -
why won't my avi fit on a dvd-r
By bigwheels103 in forum Newbie / General discussionsReplies: 3Last Post: 24th Oct 2007, 22:08
