So I want to be able to have a small Video on a regular CD
that is playable in both a CD player and a DVD player is this possable or no ? if so how ?
Thanks for your help
XanaX
It is not possible. You can combine VCD and Data, and CD audio and Data, but not VCD and Cd audio. Oh, sure it would be real nice, but unless some programming wizards come up with a way, it's out of our hands.
Dang that kinda sucks I was going to make a cd of a local band that I am friends with and put one of there Videos on the disc , now I know its possable to put say a quicktime video on a CD cuz I have the Deftones White Pony LE CD and it has Videos on the Regular CD so how did they do that , do I need some special software ?
Thanks for your Help
XanaX -
mijman is wrong, XanaXManX
The tools to create standard VCD's containing CD audio (CDDA) are VideoPack 4 (illegally distributed) and Philips Toolkit (freeware). Contact me for more information. -
As what AntnyMD stated.
VCD2.0 supports CD-DA audio tracks in the specs and you can definitely create them and still have your VCDs as compliant. However, only a couple of authoring programs support this functionality as AntnyMD described.
If you make such a VCD, it should play fine as a VCD on a stand-alone player and as an audio CD on a CD player.
Most audio CDs that have additional data material on the disc (e.g., quicktime clips) are created as "CD-Extra" discs. You cannot make VCDs in this fashion. You can author such discs with most common burning proggies (e.g., Nero or Easy CD Creator).
Regards.
Michael Tam
w: Morsels of Evidence -
So it is possable with these programs , I read about the Philips Toolkit and it looks like it was writen for Win 3.1 but theres not to much info on Video pack 4 so what one should I get and if Videopack 4 is the better of the two where do I get it ?
XanaX
Media Player Classic HC not recognizing multiple audio tracks
By DarkLight in forum ComputerReplies: 1Last Post: 31st Mar 2011, 03:50 -
how to convert dvd with dts audio to a dvd playable on a dvd player
By flannob in forum Newbie / General discussionsReplies: 5Last Post: 19th Sep 2010, 06:46 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
Media Player Classic HC not recognizing both audio tracks
By lordhutt in forum ComputerReplies: 2Last Post: 2nd Apr 2010, 19:04 -
Three audio tracks play simultaneously in Windows Media Player.
By bizzybody in forum Newbie / General discussionsReplies: 6Last Post: 18th May 2009, 01:39
