  1. Is there any freeware/shareware out there that will do this? I tried EOVideo, but it will only save as AVI. I just need something to remove the audio streams from the file so I have video only (but still as a relamedia file)...I don't see any options for this in RealProducer.
  2. streambox ripper. google search for it. and dont tell anyone i told you.
  3. "streambox ripper no longer supports realmedia files"
    ...might try and find an earlier version. thx
  4. k - found a version of it, but all it does is grab the audio from the file (EO Video can do this as well, which I would recommend cause its officially supported).
    Problem is, I really need to physically remove the audio from the rm file, so that nothing is left but video.
    Only way I could successfully do this was by using EO-Video, convert to avi without audio checked, then re-stream the video with RealProducer. However, without going back to the original source, there is significant quality loss...I hate RealNetworks!!
