I wont to know is there a better way to encode my vcd to get better quality as when i make my vcd its a bit blochy i use dvdx can someone tell me how i can adjust my settings to get a better picture or a better programme
Many thanks in advance![]()
You could try increasing the bitrate to make a non standard XVCD, or you could try SVCD. Check the DVD player compatability list to see if you player supports these formats.
Use tmpgenc and read some of the guides on here.
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
