I dont know about CPUs but I think I may have a virus or something cause everytime I try to open by double clic an mpg file directly from its directory it transform it to an exe file. In the otherhand if I open it through the player it works fine that if it hasent change to an EXE file previously. I wonder if any one can helpme, and wanted to know if I could recover those files changed to EXE
Results 1 to 9 of 9
how do you change an mpg file to a program(exe) file? i didn't know it could be done
I really have no idea it just turns tu an exe file 1nce I double clic on them.
LOL! Thats bad.
Does the file size change at all?
If you rename it back to .mpg is it ok?
Do you have a virus scanner?
Do you have any friends that think its funny to put hoax programs on your computer?
nfl2k2, you can rename any file to whatever extension you want through DOS. If you rename an .avi to .exe then it still remains an .avi in the file sense (its just called .exe instead), its just that when you go to open it , windoze thinks its an executable and produces an error. Thats all extensions are for, so that windows knows which program to open them with, thats all. -
well yeah I knew that you could change the file extension, I just don't know why you'd want to
Just found out that it was/is a virus, some Troj BLEBLA.B
Allthoug got to delete most of the files, I still have the virus cause couldnt deleate the restore something files,If anyone can give me info on where to find how to deleate them
please do so. By the way got to download a dos application to delete the virus but cant run it cause Ive never used a dos appz, it says to write fix_blebla.com on the comand prompt but dont know how to do it. please help.
Thankx -
You could try reformating the harddrive..but thats an headache if you have an cable modem and need the cable guy to reinstall your cable modem..but just in case you want to reformat you can find your computer cds that came with your computer put the recovery disk1 in restart your computer the program pops up automatically. tell it to reformat and then your finished..If you don't have recovery disks it makes it alot harder
Try here and proceed with caution that you don't mess up system files.
http://www.antivirus.com/vinfo/virusencyclo/default5.asp?VName=TROJ_BLEBLA.B -
Thought that it may have been a virus. The files -> .exe's gave it away a bit.
thestos, could you be a bit more specific? what files do you have to delete?
To use the program you got.
Copy the program you downloaded into C:\
Then open a DOS prompt (In Win98: Start>Program Files>MS DOS Prompt)and type the following:
cd\
Then press enter.
Now type:
fix_blebla.com
Press enter.
It should now run.
nfl2k2,
...you wouldnt really want to - you're right. Unless to hide files or something like that.
New CPU
By Sckinhunter in forum ComputerReplies: 9Last Post: 13th Apr 2011, 01:10 -
CPU Temp.
By HotDamn! in forum ComputerReplies: 33Last Post: 8th Mar 2010, 13:21 -
CPU
By HotDamn! in forum ComputerReplies: 7Last Post: 17th Dec 2009, 01:21 -
CPU Temp
By Willy5157 in forum ComputerReplies: 4Last Post: 9th Feb 2008, 20:22 -
CPU-Z reading for Intel Allendale cpu
By budz in forum ComputerReplies: 11Last Post: 8th Jul 2007, 19:33
