I burned my video ts folder on dvd set as dvd video once and my dvd player displayed it as a cd rom.
Why doesnt dvd video created by myself play on my standalone, and if i do burn dvd video dvds how do i know if they will play on other ppls dvd players in that format other than dvd utf which is the setting i use to burn movies?
Lee
please be more specific ...... how did you create the video_ts folder ...is it a rip of a commercial dvd or is it video u have captured and if so how and with what did you process it. what are you using to burn the dvd, what setings are you using, are the files dvd compliant etc .... we need more info before we can help you.
As pirate says but what media and what standalone. Fill out your computer specifications in profile. Will give us all a better idea of what you are dealing with.
I created the video ts file through ifoedit in some cases, but others i have just copied direct from a dvd disk
Im usign nero 6.0.1.1 or something like that.
I have burned with dvd video and dvd utf (utf setting at lowest setting for more compatability)with what did you process it.
Standalone dvd player is Alba. -
What model, exactly, is your DVD player? have you checked it will even play DVD-R's with the compatibility listing on the left?
yes it plays dvdrs, i have played copied dvds, and also dvds of my own that i have made as dvd utf format
Have you read through the thread "if your nero burned discs don't work, read this!" ?
Different versions on Nero have different issues, so it may be as simple as down/upgrading your version. I've always burned just as DVD-Video with no problems, i will let you know what version i am using later tonight.
