Which is the better format and why ?
is it worth converting from one to the other ?
PAL is better since it has higher resolution and the framerate is closer to real film.
The only reason to convert from one format to the other is if your dvd player cannot play the other format.
Converting from one format to the other will always result in quality loss, since you will have to reencode the video. -
Actually the "framerate" of PAL is only closer to movies shot in Analogue. Films like The Matrix, Lord of the Rings, or Star Wars are shot in digital at 30fps. Thus NTSC high-speed is "closer" (at 29.97fps) to the "original" film.
But PAL does have more lines in it... although 16:9 enhanced NTSC has yet MORE lines. I dunno about 16:9 enhanced PAL - is there such a thing?
- Gurm -
Films shot digitally are, in fact, shot at 30fps. They might be at 29.97fps for all I know, but it's roughly 30... NOT the 24 that "normal" films are shot at.
Wanna see evidence? Watch LOTR in the theaters. Big pans are a little jumpy. Nothing terrible, but jumpy. Now watch the DVD. Smooth as silk. That's 'cuz they're downsampled to 24fps for normal theaters.
Next... I watched Matrix: Reloaded at both a digital theater AND an Imax theater. Imax was big, the seats rumbled, and a good time was had by all... but it was kind of blurred. The fight scenes were hard to follow. In digital, they were there, perfect and pristine. 24fps downsampling can account for this as well - motion blur is introduced to make things not look jittery.
I don't think digital will replace analogue any time soon. There are a lot of things you can do with analogue that you CAN'T do with digital. But for sci-fi epics and fast-action films, digital is the way to go.
- Gurm
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
