Hi all!
I have a pioneer A06/(106) +/- R/RW
I authored a dvd with ULEAD DVD Movie Factory, with chapters.
I burned it on a DVD-RW and I am very pleased with the result.
But on one certain spot on the movie, like after 40 minutes, the picture freezes (just like I have pressed the pause button) but the sound continues normally. It's always at the same place in the movie that this appear. The funny thing is that if I play the movie fast just over the mentioned position, the movie continues normally. This is very annoying since it's an old wedding movie that I really wanna have.
I have thought of this and figure it may be a problem because I'm using a FAT32 disk as c: with Win XP PRO, but the movies themselves are all on NTFS disks. I heard there's a limitation on the file sizes and thought that this special position in the movie corresponds to that "magic limit".
OR:
It may be a result after burning on a quick erased DVD-RW, I will try to erase it completely before trying again.
Anyone knows anything about this?
Thanks!
/f96nini
Results 1 to 1 of 1
MeGUI hangs on pre-processing after extracting audio tracks
By CasanovaFly in forum AudioReplies: 2Last Post: 31st Jul 2011, 09:25 -
Only getting L and R audio from PS3 (burned DVD and blu ray)
By tikigod19 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 4th Feb 2011, 08:03 -
Audio is skipping when I play videos that are burned on a Data disc DVD!
By Xenogear900 in forum Software PlayingReplies: 8Last Post: 23rd Mar 2009, 13:12 -
no audio on iDVD-burned DVD when played on a standalone DVD player
By patroklus in forum MacReplies: 12Last Post: 10th Apr 2008, 12:56 -
iDVD 6 - No audio track on burned DVD?
By KWagner in forum MacReplies: 1Last Post: 12th Sep 2007, 10:31
