  1. I'm having a lot of problems with menus in Nero. A few months ago, I started burning the first couple VCDs of a series (with menus) and everything worked fine, but then I got busy and had to postpone the rest.
    Now, I've gone back to the same project and using the EXACT same settings as before (font, background image etc.) I'm getting the following problem: on my tv screen, the menu (including "header text") expands off the screen!
    I've tried altering innumerable settings, but nothing seems to help. I thought maybe an upgrade to Nero 6 would help, but now I just get a big black screen.
    WHAT AM I DOING WRONG?!!!
  2. Can't help you other than to say DON'T USE NERO! LOL seriously Nero VCD/SVCD's menu's suck. I would suggest Ulead Movie Factory.
    "Terminated!" :firing:
  3. ...or VCD Easy - use it to author the VCD, then use Nero to burn from the cue file.
    There are some good guides on how to do authoring/menus with VCD Easy:
    One by gonz0
    and
    One by sullen
    cheers,
    mcdruid.
    P.S. VCD Easy has the added bonus of being freeware (or at least there is a fairly recent freeware version)
