I am trying to put 3 hours of VHS cartoons on a DVD for my kids - 4 45 minute tapes. When I convert them to MPEG-2 (using the defaults) in either ProCoder or TMPGEnc, I get about 8 G worth of MPG files. What settings should I use to make the files smaller and still be DVD compliant?
Results 1 to 12 of 12
https://www.videohelp.com/calc.htm
Cartoons - I would try a bitrate of 3000+ and audio of perhaps 192
try the calc.
If you are using TMPGEnc, do the following:
Load the DVD Template
Then load unlock so you can change the settings
Enter these values For Video:
Size: 352x480(NTSC) or 352x576(PAL)
Rate Control:
For faster conversion: CBR at 2861
For better quality: VBR with average of 2861, max of 5000, min 1000
Go to audio and change the bitrate to 192
You should get the files to be slightly under 4.3 gigs with these settings and itis fully dvd compliant. -
Thanks...I'll try a lower bitrate; but this raises 2 questions for me:
1. Is bitrate directly proportional to file size? In other words, If I use half the bit rate (assuming CBR) will the file be half the size?
2. Does CBR or VBR yield a smaller file size (regardless of video quality)?
Thanks! -
Originally Posted by arrosen
2) VBR will give you a lower files size with higher quality compared to CBR. VBR is also more acurate at detirmining final file size too."Terminated!" :firing: -
Originally Posted by thayne2
Arrosen:
Iloved your topic title. I myself have become adept at creating low quality DVDs.
Here are some of my features:- Interlace problems - Might just make you sea sick
- Audio Sync - But can you really tell on a cartoon ?
- Poor Colors - Wow to the oversaturated orange and red
- And sometimes they just don't play
VBR Vs CBR w.r.t fileseize.
Only two things affect the filesize of an mpeg file. These are Bitrate and playing time.
CBR and the AVERAGE value with VBR give identical filesizes, assuming the encoder is accurate in its use of these settings. As Thayne said, VBR will generally give a better quality result than the equivalent CBR, or you can reduce the VBR average slightly, for a smaller size at 'equivalent' quality. -
Well 2-pass VBR with an average bit rate of (say) 4,000kbps is more likely to actually hit that target than CBR 4,000kbps. This is because of the differences in the predicted size of an encoded frame, and the actual size of the encoded frame. for anyone using TMPGenc, turn encode logging on next time you use it, and have a look at the figures, there's often a -big- difference here!
Consequently, the final file is not exactly the requested rate. doing a second pass allows the encoder to adjust the level of compression on the rogue frames, to get a more accurate bitrate.
So CBR is less accurate than 2-pass, which is less accurate than 3-pass, which is less accurate than 4-pass etc etc. -
Originally Posted by flaninacupboard
Even on TMPGEnc.net they are being misleading:
How can we calculate the actual size of MPEG file which will be crated?
If you choose CBR, The following equation can be used to calculate. "2048/2018" stands for bitrate of system stream.
Filesize (Kb) = (Video+Audio) x (2048/2018) x sec/8
E.g. Video is 1150Kbps, audio is 224Kbps, 15 sec MPEG file would be "(1150+224) x (2048/2018) x 15/8" = 2614KB
I guess I could do some tests of my encoders, but this ends up being academic, because I usually use vbr, give a little pad when I calculate, and rarely ever fill the dvd-r anyway.
Thanks -
DVD for my kids
I've encoded just over 5 hours on single dvdr's - used thes on longer car trips. Use half D1 and set your bitrates low (use the www.dvdrhelp.com/calc for estimating your bitrate), I've gone as low as 1200 and it's still acceptable for kids shows. I also tend to use film framerates (quality seems a little better) but that's when copying dvd's... -
Ah well, this is where multi-pass CBR comes in. acts the same as multi pass VBR, but just corrects rogue frames to fit the CBR spec instead.
I need to compress video to DVD but the quality is always lower...
By tzanaglio in forum Authoring (DVD)Replies: 6Last Post: 30th Apr 2009, 17:48 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 06:56 -
How do you lower bitrate but maintain quality?
By zanos in forum Video ConversionReplies: 7Last Post: 11th Dec 2008, 00:43 -
Convert .h264 to divx/xvid or dvd success with slightly lower quality.
By Edgelessdiamond in forum Video ConversionReplies: 13Last Post: 26th Apr 2008, 21:21 -
Lower video quality from HDV to Bluray disc or HD DVD?
By Ollie6431 in forum Newbie / General discussionsReplies: 2Last Post: 13th Nov 2007, 12:25
