My SVCD's do not play correctly. Video is perfect, but audio has dropouts and also becomes unsynchronized with the video, as if the mpg's were poorly multiplexed. However, I checked playback with PowerDVD on my PC and the mpg's are flawless as you can get when written at 2400 to 2600 kbps. This is how I narrowed the problem down to being my Apex 660, but at present am at a lost for a solution. Can anyone help me please?
I am devoting hours upon hours looking for a solution to this...at the present minute I am streching my wav file B4 I use TMPGnc...someone said this will work...I doubt it though...I think its cuz apex is only 100$ lol
If anyone knows the solution to this problem plz email me locco@ncweb.com please dont email me for any other reason because this email address isnt technically mine..thanks -
It's not the player its your encoding. Good luck. It can be a long process to educate yourself but the rewards are fruitful.
Locco . . . check out http://www.nerd-out.com/forum/list.php?f=17.
The Apex 660 is OK - my encoding techniques were the cause of my playback audio problems. Also, using VCDImager Easy, I failed to have incorporated playback control information in my SVCD's, so when I used fast forward or reverse on the APEX 660, the audio and video became way out of synch. -
i have a program playing back xsvcd using the tmpg dvd template.
also with i frame only encoding.
Ulead VideoStudio 7 Capture VHS for PC / SVCD or DVD playback
By JonnyAlpha in forum Capturing and VCRReplies: 0Last Post: 15th Feb 2010, 15:46 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 07:25 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 10:19 -
SVCD: Picture is not completely displayed during playback
By czerro in forum Authoring (VCD/SVCD)Replies: 5Last Post: 5th Nov 2007, 14:53 -
SVCD converted movie with choppy playback at the end on stand-alone player
By supernano in forum Video ConversionReplies: 0Last Post: 27th Oct 2007, 11:10
