ok folks, I used smart ripper to rip the dvd, then dvdshrink to shrink it down. THe files are small enough to burn to one dvd-r(w) and powerdvd can play the file successfully on my hard drive. I open Nero (6) and tell it to burn a dvd, it creates the emtpy project with an audio_ts folder and a video_ts folder. I copy all my .vob, .ifo and .bup files into the video_ts folder and burn.
The computer has a toshiba DVD-Rom and the NEC ND1300A DVD+-R(W) drive. If I put the copied DVD-RW into the toshiba, the little light comes on stays on and windows says no disc. If I put it in the NEC, the light comes on and all is well, except that powerdvd says that the disc is not valid that it must have a scratch or something on it, that is if I try to play it as a DVD. If I tell powerdvd to load the files on it as if they were on just another hard drive, and manually point to the video_TS folder, it seems to work wonderfully.
I think I am close here folks, but I must be missing something. Some magic step that allows other drives to read this disc properly. Any clues? (BTW, I have not actually tried this in my dvd player yet (the apex ad703) since it does nto support DVD-RWs -- only DVD-Rs (according to this site) and I would like to get the procedure down before I start burning real discs)
Results 1 to 1 of 1
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 22:18 -
Dvd-lab Read Data Size
By Burig in forum Authoring (DVD)Replies: 14Last Post: 19th Oct 2011, 19:41 -
Windows XP sees external dvd burner as cd-drive
By siskiou in forum DVD & Blu-ray WritersReplies: 5Last Post: 18th May 2010, 11:50 -
dvd r usb drive sees all burnt dvdrs as cd
By Onceler2 in forum DVD & Blu-ray WritersReplies: 4Last Post: 7th Nov 2009, 03:11 -
How Do You Read the Data from a DVD Recorded on a Combo Unit?
By Junkman in forum Newbie / General discussionsReplies: 5Last Post: 4th Jan 2009, 09:27
