  1. hi,
    I have tried every method I can think of for a movie split into two avi file with ac3 audio, if I convert to dvd or svcd or vcd the audio is well behind the film..its driving bonkers. There must be a simple way of doing this, i feel i am so close but...ah!! Been using virtual dub and tmpgenc and loads of other audio software for extracting ac3, what am i doing wrong..
    stedhew
  2. download dvd2svcd and convert using this application. use the avi template and you should have NO problems.
  3. thanks for the reply, I tried what you said video loaded great but it only loaded 8mb of audio so it went off after a few min..Is there some settings I need to adjust..
    thanx sted
  4. that is VERY strange. Post your log file here and I will take a look at it.
  5. here it is , I was doing other stuff on pc when it was decoding if that makes a difference. I dont know if I have sent log correctly..
    I will also e-mail it to you
    thanx again
    [/img]
