Closed Thread
  1. I just downloaded a DVD image of a movie. when i burned it with toast it burned fine but the verification failed. I think almost every dvd i ahve done has seemed to fail somewhere along the line of verification. I am using Verbatim DVD-R's and the Apple Superdrive. Should i try burning at 1x instead of 2? or is there another meathod to use for burning that will work?
    Donald
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator galactica
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    Topic is locked
    DONT DOWNLOAD MOVIES!
