  1. Anyone get out of sync audio when converting real media files to avi? There's nothing wrong with the source file. It's the conversion that does it. I've used both EO video 1.301 and RM Converter.
  2. I presume the only reason anybody is converting real media is to burn to disk to view on tv. There seems little point converting to another less compressed format just to keep on the pc. So when you create your mpg just use tmpgenc's source range feature to re-sync the audio.
  3. I had the same problem b4.
    Then i updated to the eo video 1.36 and I do not have the out of sync problem again.
    If you just want to view the video on tv, I recommend you to use the video card tv out function . I dont know if you have the same problem as me. i need to spend more than 3 hours to convert a 45 minutes rmvb to vcd format.
  4. I just downloaded the newest version and it did fix everything, thnx for the heads up.
