What is the most efficient way of handling in AVISynth a multisegment capture that spans multiple drives? After recently trying to use SegmentedAVISource and noting that it will only load from one drive I resorted to just frameserving from V'Dub to AVISynth which was loaded into V'DubMod.
Regards,
Golem
I haven't tried it, but you can probably use one SegmentedAviSource() statement for each drive/path because it just skips segments that are missing. You can use UnalignedSplice() or the "+" operator to join those, since UnalignedSplice is what SegmentedAviSource does anyway. So try something like this:
Code:SegmentedAviSource("D:\cap.avi") + SegmentedAviSource("E:\cap.avi")
A man without a woman is like a statue without pigeons. -
Yep, didn't mention it but I did attempt to use that one...but with a slight difference. Your code displays a space on either side of the "+" sign. I wrote mine as follows - "SegmentedAviSource("D:\cap.avi")+SegmentedAviSour ce("E:\cap.avi")" with no spaces. Written this way the code only loaded the complete second segment (no error message).
Unfortunately I no longer have segments to do a quick test but could the code require these spaces?
Regards,
Golem -
The spaces shouldn't matter, and I think that probably should have worked. Since it only loaded the second half, I wonder if it might have to do with how avisynth handles SegmentedAviSource internally. You might try an alternative syntax with the same meaning next time:
Code:UnalignedSplice(SegmentedAviSource("E:\cap.avi"), ...)
Code:s1 = SegmentedAviSource("E:\cap.avi") s2 = SegmentedAviSource("F:\cap.avi") UnalignedSplice(s1, s2) # or maybe somefilter(s1 + s2)
Thanks again for the reply sterno.
As I have a plethora of encodes scheduled right now I'll give those options a try in the very near future. Will keep my fingers crossed as I'm sure I must be inducing, even if in a minor way, some amount of performance sacrafice with the multiple frameserves (V'Dub->V'DubMod->TMPEGnc).
Btw, your sig is oh so true!
Best Regards,
Golem
Multiple Drives to Rip DVDs
By Levis in forum DVD RippingReplies: 0Last Post: 24th Aug 2011, 16:51 -
AviSynth Stack question Playback multiple videos with third video audio
By oroboros74 in forum EditingReplies: 17Last Post: 6th Nov 2010, 18:57 -
Multiple Simultaneous Video Capture - is it possible?
By PortoLad19 in forum Capturing and VCRReplies: 6Last Post: 31st Jan 2010, 08:10 -
Multiple External Hard Drives
By robjv1 in forum ComputerReplies: 1Last Post: 5th Sep 2008, 16:36 -
Capture Multiple streams to Mac
By joust888 in forum Capturing and VCRReplies: 0Last Post: 10th Jan 2008, 11:03
