I'm using MSP 7 to edit video and then generate AVIs (usually DV-AVI), but now, I'm trying to set a different codec / compressor and the program hang or crash when I try to select the AVI screen.
Same thing if try to generate (options) or to set the default project setting.
With MPEG no problem.
Any help please !!!!
THANKS!!!
Miguelo Perez
Argentina -
I hope you didn't install one of the many "codec" packs that Microsoft has warned against installing.
These can really mess up a system running Ulead MediaStudio Pro 7.0.
According to Microsoft:
"Nimo and Tsunami codec packs are untested compilations of various codecs and filters commonly used on the Internet."
"Incompatibilities are known to exist with some of the components in the packs."
"The incompatibilities can cause serious playback issues in Windows Media Player and other multimedia programs, lead to system corruption, and make it difficult for Microsoft Support to diagnose and troubleshoot playback issues."
http://www.microsoft.com/windows/wi...CS1#NAME_CODECS
Jerry Jones
http://www.jonesgroup.net -
Thank you ! The problem was the Nimo pack.
I've removed it and everything is normal... with MSP but the player (xVid,AC3,subs,etc.).
Best regards,Miguelo Perez
Argentina
Avid Studio vs. Sony Vegas Pro/Studio
By HoosierGuy in forum EditingReplies: 12Last Post: 8th Dec 2011, 20:06 -
Vegas Movie Studio 10 crash
By magillagorilla in forum EditingReplies: 46Last Post: 29th Aug 2011, 01:35 -
...setting webcam's parameters programmatically
By alexjep in forum ProgrammingReplies: 0Last Post: 12th Dec 2007, 11:36 -
Slowing down video not Audio using Ulead Media Studio Pro 8
By engert100 in forum EditingReplies: 10Last Post: 25th Oct 2007, 15:17 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 00:38
