All the videos I EDIT with Pinnacle Studio 7 are taking an average of 1hour for every 4 minutes of video to CREATE the film. Example:- a 15 minute video on the timeline takes 4 hours to CREATE. With a 26 minute Timeline I left it overnight and it took 8 hours to CREATE a video.
Surely I am doing something wrong or is this normal ?![]()
I use the "make a VCD " setting and it produces a MPEG 1 (EVENTUALLY) and I am pleased with the results but not the time taken.
I have a 1.6 Mhz PC running Windows 98 with 256 memory and have an 80Gig hard disk with 50 Gig freespace.
Can anyone suggest a solution to speed things up OR is this the normal time taken.
Ron Rushbrooke. Newcastle, UK
Thats whacky.
Using TMPGEnc, 1.6GHz P4, 512MB RAM, 20GB HD for MPEG2 SVCDs, so higher res and higher bitrates then MPEG1 VCDs. for A constant Bit Rate it takes me 2:1 so 2 Hours to encode 1 Hour of Video. I mostly use a 2 Pass VBR now, and thats 3.5:1 so 3.5 hours to encode 1 hour of movie.
Corse I use AVISynth to do everything but encode, so I do all my interlacing/IVTC/Resize/FPS Converting in that, which improves encoding time.
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
Thank you folks for the helpful replies. I will try everything you suggest to see if it helps.
Ron Rushbrooke -
Any luck ? My ratio is about 1:5. 1h of video takes aboiut 5h to create DVD.
Pinnacle Studio 8 and DV home video editing (ver.9 already home)
spit 4 hours wmv into 1 minute parts
By pribl in forum Newbie / General discussionsReplies: 1Last Post: 16th Jun 2011, 04:45 -
Slow motion at least 1 minute long clips?
By owen bryan in forum Newbie / General discussionsReplies: 4Last Post: 27th Nov 2010, 21:08 -
FitCD thinks 43 minute video is 2 minutes long - ditto TMPGEnc
By natrap in forum Video ConversionReplies: 3Last Post: 2nd Aug 2009, 21:02 -
Splitting long (hours) MP3 files by sound breaks
By lostinlodos in forum AudioReplies: 3Last Post: 19th Mar 2009, 21:37 -
Hours of Music without Hours of Video Data in DVD Architect
By Guff22 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2008, 21:23
