    Feb 2003
    England
    Hi,
    I have tried encoding a few films in DivX using DVDx. One of them my DVD of TrippleX just to see if I can use it. One thing I have noticed on the outputted file the colours mainly blacks aren't as deep and bold as they are in the original movie even when I put the bit rate and resolution up high. I was wondering if I can access some sort of colour settings to change this.
    Thanks for any help.
  2. have you set the post processing (when playing back the movie) to high?
    The electronic components of the power part adopted a lot of Rubycons.
    Feb 2003
    England
    I will try that feature but even when I play other divx movies that I havent made (namely the Pr0nStarS version of Matrix Reloaded DVD rip) the colours are well defined not like mine.
