Hi all,
i'm sure that this question has already been asked before but i've search in this forum,read a lot of comments and... i'm going mad...
I have a movie with AC3 2.0 and i would like to transform it in AC3 5.1.
My decoder uses Dolby Prologic to decode the sound on my Home Theater. So i would like make the self decoding but with software.
My Idea is to:
extract from AC3 2.0 with a Dolby Prologic decoder to create 6 wavs
transform 6 wavs to AC3 5.1.
Is it possible and if yes with wich tools for the extract and the transform.
Tks a lot.
Tharkysis
yes it's possible. if your sound track is Dolby Surround encoded (not all 2.0 files are) then you can extract a rear and centre channel.
But why bother? what is the point? any Dolby Digital 5.1 reciever you plug into could just as easily decode the stereo in Pro-Logic. you don't gain anything by recording a Pro-Logic output and creating a 5.1 file.
And yes, this is covered about 2 topics down. and about 5 topics down. and about 10 topics down.
Convert AVI with H264 and AC3 to AVI with XVid and AC3
By ashwin.terminator in forum Video ConversionReplies: 4Last Post: 26th Jul 2009, 12:17 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
Convert from AC3 5.1 to AC3
By jollyjohn in forum AudioReplies: 2Last Post: 21st Mar 2008, 08:04
