I'm using a Toshiba SD R 5002 DVD writer and Princo DVD-Rs.
I ripped some movies using DVD Shrink 2.3 and burned them with Nero 6. That all worked fine.
Then I started watching the movies, and they begin hanging now and then for about a little less then a second.![]()
The errors become more the longer the movie is playing.
Seems like a decompressing problem, I'm using a JVC S 300 DVD Player.
Has anyone an idea what might me the reason for this?
Thank you so much!
If you had done your homework, you would have read quite a lot of issues like this with cheap (RE:"crap") media.
Follow the bug's advice and get better blanks.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Thank you that was a good help for me.
Has anyone some experience with BulkPAQ media, www.bulkpaq.co.uk
Is this also crap? -
Champaign82, you should definatley read this post:
https://www.videohelp.com/forum/viewtopic.php?t=172496
Good luck.Live Long, Play Hard, Think BIG! -
Since you're quoting UK sites, why not check out the sample packs from
http://www.blankdiscshop.co.uk and http://www.cdrmedia.co.uk
Try Riteks, Mirror (AN31), Nan-ya etc - Bulkpaq have improved recently but I still have problems with them near the edge (so far I have found the turquoise ones to be the best on my picky Sony DVD player).
portable DVD player cracking sounds then hangs
By dzsoul in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th May 2009, 07:29 -
Slow motion FX hangs DVD players
By Canopus Smoker in forum Authoring (DVD)Replies: 5Last Post: 17th Dec 2008, 17:18 -
DVD Hangs in one Area
By gjordan12198 in forum Newbie / General discussionsReplies: 2Last Post: 10th Jun 2008, 22:37 -
Any good ideas for an engagement DVD?
By Rudyard in forum Newbie / General discussionsReplies: 2Last Post: 3rd Dec 2007, 22:03 -
New DVD hangs; copied to hard drive with IsoBuster but cant burn
By bernie01 in forum DVD RippingReplies: 5Last Post: 1st Aug 2007, 17:36
