I have an problem and it seems to happen way to often. I am trying to make a movie straight to disc. I click create disc,it starts rendering, but then it stalls. I have tried a number of times with the same results. It seems to be the same part of the video in which it stalls. Task Manager says it is running, but it does not move. The video is an AVI file 640x480 which I am trying to create an SVCD. I am using Pinnacle Studio 8.8 on an pentium 4 1.9Ghz with 512 of ram on an XP system. Is this a problem that can be fixed? Has anyone else had this problem? How do I fix the problem? Any help will be much appreciated, Thanks!
Are you using a menu? If yes, remove the menu. Render to avi using DV encoder. Close. Re-open the avi. Re-insert into the timeline. Now re-add the menu and chapter points. Make disk.
If not using a menu.
Render to avi using DV encoder. Close. Re-open the avi. Re-insert into the timeline. Make disk.
Your hang could be due to a few reasons. Not sure what your is. Use the Studio users forum. There a great help.
http://webboard.pinnaclesys.com/read_forums.asp?WebboardID=1&SectionID=143&lng=1&Produ...DocTypesID=181Geronimo -
Pinnacle Studio 8.x can hang during MAKE DISC if you have a chapter point right in a transition. Avoid that or follows the previous suggestions.
I stop using PS8 for making disc or DVD content. It's S L O W , so I just use it for capture and video editing.ktnwin - PATIENCE -
It used to take me 45 minutes to render a VCD with Studio 8.7. With 8.8 it takes about 2-1/2 hours. My solution was to use 2 partitions on my HD (or just use a 2nd HD). I have the same OS on both partitions, but one has Studio 8.7 and the other has 8.8. I use 8.7 to capture an avi, then edit the avi and render it to a VCD (or SVCD) compatible mpg.
You can load that mpg file in Studio 8.8 and add menus and chapter points. Then it takes less than 10 minutes to render the final VCD and burn it.
SONY Movie Studio Platinum 10 rendering problem!
By EagleW in forum EditingReplies: 4Last Post: 4th Nov 2010, 18:52 -
Sony Vegas Movie Studio 10 rendering problem
By videogirl214 in forum EditingReplies: 1Last Post: 19th Aug 2010, 00:29 -
Pinnacle Studio: Pan and Zoom/Rendering Problem
By ashleyvideogirl in forum EditingReplies: 0Last Post: 18th Jan 2009, 04:30 -
Trying to edit avi in Pinnacle Studio: PROBLEM!
By L3Wi5 in forum Newbie / General discussionsReplies: 5Last Post: 25th Sep 2008, 13:09 -
Pinnacle studio program stability problem
By SearchQuality in forum Newbie / General discussionsReplies: 4Last Post: 14th Nov 2007, 21:06
