I'm trying to put an amuteur movie i have made on to dvd. We want a number of audio tracks (i.e. main + commentary) and so we are using maestro.
I thought that the files i have would be compatible. They were created using premiere 6.5's Export Timeline - Adobe MPEG Encoder, with the settings set to output as dvd file.
the files are not compatible, so i need to convert them to the file type that maestro supports. What software is there to do this? I tried using Cucusoft Video Converter but the image jutters. What other programmes might i try?
If you've exported them to mpeg2 from adobe premiere. Then the chances are the audio and video have been encoded as one. Maestro will not allow mpg files to be imported in this state. You must split the mpg into audio and video using a demultiplexer; found in such software as TMPGenc. This will create two files one with the ext. Movie.m2v (video)and one with movie.mp2(audio).If this doesn't solve it; then the chances are you've breached the allowed resolution or bitrate, for a dvd.
Properly preparing a VOB with pulldown for Vegas Pro 10.
By rcavanah in forum EditingReplies: 10Last Post: 14th Sep 2011, 16:51 -
Some steps I've heard recommended for preparing old videotapes for transfer
By JQK18 in forum Capturing and VCRReplies: 7Last Post: 23rd Mar 2010, 00:40 -
Preparing Video on a PC for editing on a Mac with iMovie ?
By beammeup in forum MacReplies: 5Last Post: 13th May 2009, 19:57 -
Preparing Video for YouTube
By markannab in forum Video ConversionReplies: 121Last Post: 28th Aug 2008, 19:47 -
Preparing for preview with avisynth
By themaster1 in forum Video ConversionReplies: 0Last Post: 28th Oct 2007, 18:54
