I'M USING TMPGEnc TO CONVERT JPEGS TO MPEG BUT ONLY ONE AT A TIME. CAN TMPGEnc BATCH PROCESS IT (if so how?) OR DO I NEED ANOTHER PROGRAMM.
Dom-jenn@home.com
Set your encoder settings for one file, select file>Add current project to the batch list. Do this with all the jpegs, then select file> batch encode> run.
I just select the .jpg as video source and convert....
Maybe you should go to option> enviromental setting> VFAPI and set a higher priority for still images.
<font size=-1>[ This Message was edited by: Truman on 2001-10-02 16:39:41 ]</font>
How can I batch process AVI files and overwrite the originals? Please help!
By DrivesALot in forum Video ConversionReplies: 5Last Post: 21st Oct 2011, 20:59 -
Can I batch process some mp3's with Audacity to make them louder?
By snafubaby in forum AudioReplies: 2Last Post: 10th May 2011, 13:24 -
Delete Source Files after batch process has ended
By Metallo in forum Video ConversionReplies: 3Last Post: 24th Mar 2010, 18:10 -
How to Batch Process Using Avidemux? Or Batch Processing H264 .m2ts or .ts?
By forgotpassword in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 00:00 -
How to Batch Process With HCEnc
By freebird73717 in forum User guidesReplies: 13Last Post: 18th Jul 2007, 21:14
