  1. I currently have 512mb PC800 RDRAM
    how much of a diffence will I notice to processing large image files etc if I add another 512mb ?
    will it be worth the upgrade as rdram is pricey
  2. This would've fit better in the new Computer forum, but I'll answer it anyway.
    I doubt it will make much of a difference - after 512 MB, it is hard to notice a performance gain.
  3. Originally Posted by freestyler
    Will make a difference but I agree not considerably upgrade your processor. You do not list your comp specs, what are they ?
    If it's wet, drink it
    My DVD Collection
  4. P4 2.4ghz
    2 X 120gb Hard Drives
    Intel D850MV mother board
    NEC1300A DVDRW
    TDK CDRW
    SB Audigy Sound Card
    NVIDIA GeForce 4 Ti 4600 Graphics card
  5. CPU is more important than ram. You might a few nano seconds faster, but not worth the cash
    "Terminated!" :firing:
  6. It really depends on what you're using your machine for...
    Dealing with trully large image files (stills) uses a lot of memory - so if you're using your machine to design and edit a billboard, then the memory upgrade might be worthwhile.
    If you mean, however, video editing - then the others are right; for encoding etc.. the CPU is so busy number-crunching that the memory never gets that heavy a load.
    I personally think that anything over 512mb is slightly overkill on a single-user PC at the moment (unless you're using your machine for something unusual as I said above). Probably in a few months/years 1gig will become the norm, but I've never personally seen my machine have to resort to the paging file in a big way - with only 512mb installed.
    cheers,
    mcdruid.
