How am I able to add a border to my mpg's before encoding, so they screen shot isn't cropped when I view them?
any help would be appreciated ..
cheers
Which kind of soucre file do you have? What is the aspect ratio? Which tools would you like to use?
<font size=-1>[ This Message was edited by: Truman on 2001-10-02 14:26:53 ]</font> -
Files are '.mpg'
Asdpect ratio is 4:3
The only program I am remotely familiar with is Tmpg Enc. -
Actually I wonder why do you want add borders to a 4:3 MPEG.
You could crop top and buttom lines using "clip frame" at the advanced tab and add borders (add mask). But this makes no sense to me. -
You can get borders in TMPG without cropping - set the output size to whatever you want it to be, then under the Advanced tab, double click 'Clip Frame', click 'Arrange Setting', choose 'Center (Custom Size)', and enter settings slightly smaller than your output size.
You can also do this right on the Advanced menu page, but doing it under 'Clip Frame' enables you to preview exactly what the output will look like. -
Thanks peoples.
My mistake Truman, the film clips were shot in 4:3 aspect, but the mpgs are 16:9 format
tnhanks again -
If you have a 4:3 source just select source aspect ratio 4:3, video arrange method "full screen(keep aspect ratio)"
at TMPG's advanced tab. At the video tab set aspect ratio to 4:3.
No crop, no resize, no nothing...
Partial upconvert of DVD, add black border = Bluray
By HDTV's Frank in forum Authoring (Blu-ray)Replies: 3Last Post: 13th Jun 2011, 01:15 -
flickering border
By stompinne in forum Authoring (DVD)Replies: 5Last Post: 22nd Apr 2009, 12:34 -
DVD Software that doesn't add black border
By Maikeru-sama in forum Video ConversionReplies: 8Last Post: 3rd Dec 2008, 13:08 -
Overscan border
By milway in forum Authoring (DVD)Replies: 5Last Post: 1st Jul 2008, 17:03 -
Request: Please improve add border feature for overscan problem and menu
By maxxjulie in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Jan 2008, 19:36
