I can't find a damn thing about it on the web!! NOTHING! i am the first person out there to get one?
Just picked it up from Walmart in Canada for $89..
player is great, has dolby digital/DTS, progressive scanning, VCD, SVCD, MP3..
Only problem is that it sets subtitles ON by default.. how @&#!'n stupid is that.. I can disable them on all the movies i have except The Mummy Returns.. so i am hoping this doesnt happen on many more new movies.
Anyone else get this player? same subtitle problems?
I'll see if i can't get a digi cam and take a pic.. maybe it will end up being the same player as someone has but with this different AudioLogic name to it.
Results 1 to 10 of 10
Dr|zzt
Hi,
Just got a couple of these myself on clearance for $50 canadian each, I also can't find much out about them. I've been able to make them region free using a suggested hack for Audiologic-101 but have not been able to defeat macro yet, wonder if there is a way? -
You are right there is no info on the internet about this DVD player.
I bought my audio logic ADV802PS a few days ago. I too have a problem with the subtitles always on by default. Where did you buy yours for $50.00 CDN? I payed $89 for mine. Does it play SVCD and VCD? I found nothing in the book about those formats. -
Hi There
DrizztXII - did you ever take those pictures of your machine?Preferably internally too.
Also could someone provide me with the firmware version listed under Others (normally)
If so could you fire them over to the webmaster---@---adl528.com (remove the dashes).
Have a look around that site - kotron dvd-101 and cyberhome 528 specifically - do not try to upgrade your firmwares using any supplied on this site.You'll kill your machine.
Is it still possible to get hold of these machines and if so do you know if they will export to the UK?
Jeremy (bullfrog) -
Hi
Forgot to say to get rid of the subtitles change the subtitle language under the players setup menu to a Language that isn't likely to occur i.e. Language Zulu.
Not sure if the ADV802PS manual lists the codes for Languages if not let me know I'll get back to you.
Perhaps someone can send me a copy of the manual too.
Regards
Bullfrog -
bullfrog? Posted the hack on his site http://adl528.com
Region free hack:
- Eject tray
- Press Stop
- Enter 1999 -
Any possibility of pictures of this machine and/or screen dumps.
What version of firmware does it run? - should be under others - version.
Bullfrog -
It doesn't belongs to me, was helping a friend to watch a korean R3 DVD
I think I can get the firmware version, no digi-cam though... -
Hi
I look forward to any details,you are able to provide.Would I be correct in assuming this is a standalone player,i.e. not a TV/DVD combo.Information on the Internet regarding this unit is literally non-existant.
Thanks again for you help
Bullfrog -
Yes it's a standalone DVD player, with a front LCD and is rather tall in height
I will try to get a picture with my trow away camera and scan it when I have time
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 08:28 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 13:55 -
Player nightmare! (BS Player and Media PLayer Classic)
By 2710 in forum Software PlayingReplies: 1Last Post: 9th Jul 2010, 07:28 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 10:15 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 07:05
