Hi to everybody!
To put several MPEG2-Files (elaborated by DVD2SVCD, header-trick used, no reencoding required) on a DVD(mpeg) works fine for me. The maximum highlight would be, if I can get it done that there would be 2 languages (with dvd2svcd the extraction works perfect) to switch on the DVD(mpeg). Has everyone tried this successfully? I would be grateful to hear from you in the case of affirmation.
Thank you in advance.
Yours, Diogenes
Currently SVCD2DVD/MPG only supports one audio stream. Once things settle down this will probably be the next goal - to support multiple audio tracks and so multiple languages.
Thank you for your answer, ChrissyBoy. I just thought it should be possible, because making an SVCD-image it is possible to get 2 audio-streams and switch between them on my Phonotrend-DVD-Player...
yep its very possible and has been on the radar for some time but i haven't had the time to turn my attention to it.
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
So, let's pray for some more time to ChrissyBoy...
Thank you!
Diogenes
P.S.: Any idea about the point of time concerning the next radaring? -
I haven't been here for a long time now. Perhaps, now 2 audio tracks are supported...
ChrissyBoy, can you tell me more about this?
Thanx in advance
Diogenes
Good Languages vs. Bad Languages?
By hech54 in forum FeedbackReplies: 8Last Post: 17th Mar 2012, 13:56 -
Removing languages from a .sub
By kyrcy in forum SubtitleReplies: 5Last Post: 9th Feb 2010, 16:31 -
Multiple audio languages and subtitle languages
By BobAchgill in forum Authoring (DVD)Replies: 4Last Post: 15th Aug 2009, 12:44 -
Languages -- Subtitles...
By GRAMOPHONE in forum Authoring (DVD)Replies: 3Last Post: 22nd Apr 2008, 17:50 -
Languages For IMGBurn?
By hech54 in forum Newbie / General discussionsReplies: 4Last Post: 26th Sep 2007, 01:35
